Ir para o conteúdo principal
Nissan unveiled the seventh generation Sentra in August 2012. The new Sentra is completely redesigned inside and out but is a rebadged Chinese and Japanese market Sylphy.
engine reving up and down while driving at a high speed
why is the engine reving up and down and the rpm’s going up and down while driving at a high speed?
Esta é uma boa pergunta?
Pontuação 2
2 comentários:
When does it happen exactly? Or is it completely random? While in cruise control? Going uphill or downhill? More details!
por
When RPM's go up and down does it feel like the car losses power? Could this be a transmission that's going out? Is it stick or automatic?
por
Adicionar um comentário
1 resposta
If it has an automatic transmission, the ‘kickdown’ probably needs adjusting. If you say that to your mechanic and describe you symptoms, he should know what you mean.
And here’s an article explaining kickdown if you’re interested.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
connie shelton será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 11
Ao todo: 1,580
