Ir para o conteúdo principal
Lançado em 22 de setembro de 2017. Modelo A1864, A1897. Disponível como GSM ou CDMA / 64 ou 256 GB / Cores Ouro, Prata e Cinza Espacial.
Replacing glass screen & True Tone function
I cracked my phone yesterday, which normally wouldn’t have been a big issue but the crack is located over the front camera which distorts the lighting in pictures. I don’t think the LCD display is damaged and that only the glass part needs to be replaced. However, I did some research and found that True Tone disappears if you get it repaired by a third party (non Apple). Is that still an issue?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
If you have access to an Ambient Light Sensor programmer, then you can copy over the settings from the original screen to the replacement one. Otherwise, you may want to have this done by an independent repair shop or by Apple in order to retain TrueTone.
Esta resposta foi útil?
Pontuação 3
1 comentário:
The repair shop I’m planning to take it to isn’t an “apple authorized” place, however. Would that still disable True Tone?
por
Adicionar a sua resposta
Smm será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 840
