Ir para o conteúdo principal
O Wonderboom é um alto-falante portátil Bluetooth da Ultimate Ears. Lançado em 2017. Número do modelo: 984-000839.
My Wonderboom is frozen.
Today my UE Wonderboom suddenly stopped working, however it will not power down. The power light blinks but it will not turn off, pair, or anything else. I tried the factory reset, and it will not work. Can anyone help, please? Thank you!
Esta é uma boa pergunta?
Pontuação 5
Adicionar um comentário
3 respostas
Solução escolhida
I just spoke to UE customer service. I had to perform what is considered a “hard reset”. Press the volume up (+), volume down (-), the power button, and the Bluetooth button for about 15 seconds. My speaker is now back to normal. I hope this helps someone who might have the same issue.
Esta resposta foi útil?
Pontuação 15
12 comentários:
I was wondering how to do it on the WonderBoom, good info!
por
Thanks had the same issue and it worked !
por
No problem! I’m so glad it worked for you!
por
Hey, I'm having the same problem. I accidentally charged my wonderboom for10hrs. Now power and Bluetooth lights are ON. Tried reset and hard reset. But still it's not working. When I press volume up (+), volume down (-) and bluetooth button together, the lights go off and again back after releasing.
por
Exactly same thing has just happened to me, did you resolve it in the end? If so how?! Many thanks!
por
Exibir mais 7 comentários
I would contact UE, hopefully your warranty is still valid!
Pontuação 2
Wow this actually worked. Thank you so much for
Pontuação 2
Adicionar a sua resposta
Christopher Osborne será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 123
Ao todo: 24,645
