Ir para o conteúdo principal
Guides for the LTE version of the iPad Mini 2. Announced October 22nd and released November 12th, 2013. The iPad mini 2, originally known as the iPad mini with Retina Display, has all the pixels of the iPad Air in a smaller 7.9" form factor.
62 Perguntas Visualizar todos
How do I turn off my iPad when I accidentally took out my front panel
So I was following a guide in Front Panel replacement and I didn’t turn off my iPad before taking the front panel out.. Now I am in the process of taking out the LCD, how do I turn my iPad off?
iPad Mini 2 LTE
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Unplug the battery first then unplug the other cables. Unplugging the battery is the same as turning off the iPad.
Esta resposta foi útil?
Pontuação 1
1 comentário:
To add to this, the battery connector is right next to the LCD connector as shown starting at Step 40 in the LCD replacement guide: iPad Mini 2 LTE LCD Replacement
Disconnect both and you’ll be good to go!
por
Adicionar a sua resposta
Synergy Plays será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 43
