Ir para o conteúdo principal
Repair guides for feature cell phones manufactured by LG. This category is for phones not using an Android or Windows operating system.
204 Perguntas Visualizar todos
My phone acts weird
My phone acts weird when I put headphones in it keeps going to Google assistant and then it lags, and even when I'm not using headphones my data is acting weird. My phone only connects to Wi-Fi not data or hotspot so I can't use it outside of the house.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Hi ,
What is the model number of the phone?
Try starting the phone in safe mode to see if it works normally.
(Hopefully this safe mode procedure will work for your LG model. If it doesn't search online for LG (insert model number of phone) safe mode to find the correct procedure for your model phone.
If it works OK when in safe mode, then a downloaded app is the cause of the problem.
You need to uninstall your downloaded apps, one by one, and test the phone in "normal mode" between each uninstall to see if it works OK.
When it does then the last app that was uninstalled was the culprit.
If it still doesn’t work normally when in safe mode, try a factory reset to see if this resolves the problem.
Before performing the reset, backup the phone using the phone’s backup feature
''Be aware that a factory reset will erase all your data and downloaded apps. it will restore the phone to its’ factory default condition. That’s why it’s important to backup the phone first.''
When you have completed the backup, factory restore (or reset) the phone using the phone’s factory restore feature.
When the phone has been reset to factory conditions, test the phone to see if it works normally.
If it does then restore the phone with the backup that you made earlier, using the phone’s restore feature.
When the phone has been restored to what it was, test that it still works normally.
If so then the reset has resolved the problem.
Esta resposta foi útil?
Pontuação 1
Software issues. Don't worry about it.
Pontuação 0
Adicionar a sua resposta
Tiara Hagan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 205
