Ir para o conteúdo principal
Repair guides and troubleshooting information for microwave ovens.
759 Perguntas Visualizar todos
My microwave is not heating, but the timer is working.
My Frigidaire microwave oven is not heating. The countdown timer runs as if it was heating, but that's about it. Any suggestions?
Esta é uma boa pergunta?
Pontuação 35
18 comentários
Personally I would suggest that you take it to a professional for that repair. Those things are wicked and not meant to experiment with. THEY CAN ACTUALLY KILL YOU, so take it to get fixed.
por
If your microwave oven stops working then you should get a professional. It could be that the power is cut off by something like a fuse failure. DO NOT tinker with your microwave oven because they can give you VERY NASTY SHOCK. IT WILL MOST DEFINITELY Electricute you.
por
Now a days microwave oven has become common in every home. First you must have to know the trouble shooting tips so that you can repair it yourself has a HVAC trainer i have some tips for you to follow http://www.hvactrainingwebsite.com/ before repairing follow the precautions be aware that the appliance is not plugged in and do not touch the wire or components until you discharge the high voltage capacitor and do not work alone you need a professional to help you.
por
Here's the how to fix it yourself guide
https://youtu.be/WAf18e8sW4E
por
No heating microwave issue is likely from defective magnetron. If you have basic confident working with electronic, replacing this part is not difficult. There are several instructional video posted online. Just make sure you follow all advice when replacing it. I recently replaced one on my microwave that saved me hundreds dollars from buying a new one.
por
Exibir mais 13 comentários
Adicionar um comentário
17 respostas
Solução escolhida
My first thought would be a blown magnetron. On microwaves, these can generally go dead, usually with a popping sound. I think there might also be a fuse in your microwave, but I do believe that if it was a blown fuse, your MW would not start up. The technician should also not forget the door switch since some of them can cause the same issue. My solution would be to A: Call a trained appliance technician to replace the magnetron or B: buy a new microwave. Microwaves have really gotten very inexpensive and probably will cost you less than the parts and labor for the repair. I STRONGLY SUGGEST NOT TO MESS WITH THIS. MICROWAVES ARE TRULY DANGEROUS. You do not want to fry yourself. Strictly from an academic point, it could be the power diodes or a defective capacitor. Your microwave may turn on but does not heat. Remember the frying comment above, this is the part that will not just curl your hair, but will most certainly be a shocking experience. DO NOT MESS WITH IT. The magnetron can be tested by setting an ohmmeter to its highest resistance scale. Then, touch one of the meter's probes to a magnetron terminal and the other one to the metal magnetron housing. The test should produce a reading of infinity - indicating an open circuit.
For more info check on here
Again, this is for academics only, DO NOT ATTEMPT TO FIX IT YOURSELF unless you are trained in high voltage. Good luck and STAY SAFE.
Esta resposta foi útil?
Pontuação 20
6 comentários:
In complete agreement +
por
One must first unplug the microwave oven from the mains supply. Upon removing the sheet metal "skin" one should then "crowbar" or short out the high voltage capacitor with an insulated screwdriver. Once the capacitor has been discharged, it is perfectly safe to work on the oven and remove parts for bench testing. There should be no need to work on the oven with mains power applied.
por
I understood that SHORTING OUT a capacitor can damage the insulating sheets within the device?? I seems that most if not all use a wire connecting the cap to earth so to drain the device.
por
john a, the high-voltage capacitor in most microwave ovens is bridged with a high-value bleeder resistor for safety. It's likely that once the oven is turned off and unplugged, the capacitor will be discharged long before the sheet metal housing is opened. Shorting it out is just an extra precaution.
por
The recent models MW ovens have a high value resistor that discharges the capacitor (5,000 V, ? F). But even with a discharged capacitor, MW oven may poison you. There is a white insulator made of BeO. Beryllium is very dangerous toxic metal. the white insulator may brake and form dust yo don't want to breathe.
por
Exibir mais 1 comentário
The kind of failure described in this section could be due to failure of the magnetron tube, the power relay that supplies the magnetron tube, or the high voltage supply for the magnetron, especially if the turntable, fan, light and controls all still appear to be working.
I recently resurrected a dead G.E. Profile built-in microwave oven whose power transformer had failed in a most smoky and smelly fashion. The display and touch pad control still appeared to work, but it didn't heat anymore. The fuse didn't blow. After the oven was taken down and the skins were removed, the failed part was visually obvious. Even though it was 5 years old and well out of warranty, we were able to get a replacement transformer from G.E., and after about a half hour of reassembly, I was able to plug the oven into a heavy duty extension cord and start it up on the bench. I wiped the the oven cavity with household ammonia to remove the smoke residue as much as possible. A bit more work and it was mounted on the wall again and back in service, although it took a couple of weeks for the remaining acrid smell to fully dissipate.
Magnetron tubes are very reliable and not very likely to fail in less than 10-15 years. You'll probably get tired of the oven before the tube burns out. The high voltage transformer is the most likely thing to fail. Since the transformer has both high voltage and low voltage secondary windings, it is possible for the high voltage winding to fail, yet the low voltage section to still work and supply power to the electronic controls. The next item after the transformer is the silicon rectifier used in the high voltage DC supply for the magnetron.
The filter capacitor in the high voltage section is usually bridged by a high-value "bleeder" resistor to discharge it when power is turned off. It should be safe to work on within a few minutes after power is removed from the oven, although to be sure, one should short the capacitor terminals together with a screwdriver or other insulated tool before doing any work. Unless you are equipped with proper high voltage test gear and are trained in working with high voltages, you shouldn't work on a live magnetron circuit, as it can kill you. The reason I felt safe in tackling this job is that I'm an electronics engineer with 40 years of experience, including training in vacuum tube circuits.
Pontuação 15
Your microwave oven not working?
I am sure tht many answers blame magnetron is faulty. Why, because is expensive and not worthit to fix. I fixed nearly 200 microwave ovens ( customers returns from shops) and only about 4 magnetrons need replacement, usualy in branded models. High voltage transformer is rare to get faulty ( about 2 out 200 ). Will smell burning smoke from apliance, it is from high voltage transformer.
First thing, microwave oven is very danger apliance to repair due high voltage. If you do not know how to deal with electric items ask specialist. On my blog will find instructions how to fix microwave oven.
The most common fault and very cheap to fix is microwave oven high voltage fuse. This part is attached to tranformer in black or white plastick tube. Need carefully open this tube using flat screw driver. Will see glass fuse, clearly will show you if is ok or need replacement. If you replace this plart, before try apliance if working is got to check high voltage diode and capacitor. If one of this parts faulty, your new fuse will burn again in seconds.
Door switches are for safety, have nothing to do with warming food.
Pontuação 11
2 comentários:
Door switches are so the microwave doesn't run and leak out any radiation, the fuses are slow blo 15 amp fuses that you can't see inside all micros have had them since their first design hit the market and how come your scaring the poor guy about the so called dangers of the high voltage in micros? you probably don't even know that there has NEVER been a fatality from someone fixing a microwave , TVs have 5 times more stored up voltage that micros have, you need to study the theory behind microwave operation, unless you like making the homeowner get stressed out even more than he is because of what he thinks the bill is going to be, man I
was always making the customer understand exactly how their appliance operated so they would be put at ease, knowing they didn't put a potential bomb in their house by mistake, I'm sorry real technicians get a bad name when they get confused for a repairman, I was trained to be a full line technician, residential, commercial and light industrial, micros were a hobby.
por
I'm not familiar on how to repair a Microwave Oven, mine is a vintage built-in Whirlpool MO inclusive when the house was newly built in 2005 that stop working recently but, lighten upon reading your passage on the topic. Thank you, friend!
por
I have a GE Profile and everything worked but it would not heat. If this is the case with your microwave then here is what I suggest. Open up your oven by removing the top cover. Let it sit UNPLUGGED for 30 minutes or better yet you MUST discharge the HIGH VOLTAGE CAPICATOR. The capacitor has enough voltage to kill you. If you do not know what a capacitor is or how to discharge it look for a video on UTUBE. Then do the following:
1. Locate the transformer. Take of the two leads usually a red wire and a white wire and take them off. Note their locations for reattachment.
2. Take a digital multimeter with the red lead and place it into 500V and the black lead into COM. Place the rotating switch on 200V.
3. Take the red and black leads and place one lead into each of the transformer wires. Place the red lead into the red wire and black lead into the white wire.
4. Plug in the microwave oven.
5. Start the microwave.
6. Turn on the Multimeter and read the voltage.
7. If the voltage is 118 to 125 then then your front panel is working correctly. Unplug the unit and let it sit for 30 minutes to discharge the capacitor or discharge it. This leaves only four possible problems. It is either the transformer, the capacitor, the diode or the magnetron.
8. my case I did not test the transformer or capacitor because they rarely go bad and the test equipment is about $150.
9. So I just bought the diode, about $10, and replaced it.
10. I also bought a magnetron for $102 and replaced it. Again look for video on UTUBE if you are unsure of what a diode and magnetron look like and how to replace them.
11. Reassemble, plug it in and test for two minutes on high with a cup of water.
After I did these things the unit worked like new. Hope this helps and good luck.
Pontuação 8
1 comentário:
A rather expensive repair: $112 for the two parts, plus how many hours of work? Would it not be cheaper to buy a new micro?
por
I fix microwaves for a living, they store over 4 thousand volts in the high voltage section, and if you don't know what you are doing, don't take the cover off.Yours could be one of several problems, if it programs and goes through all the motions but no heat,then you have some type of high voltage problem, that could be a bad high voltage transformer,capacitor,magnetron on rectifier.take it too a pro or have a pro come to your house.good luck
Pontuação 6
3 comentários:
+ like rj713 said "in complete agreement"
por
I have a Frigidaire Microwave and when turned on, it makes a rumbling sound and does not heat, everything else works. Do you have any idea's what it could be. I used it maybe 30 times at best. Thinking the Magnetron is the problem. Because it is a few years old, they refused to replace it, when the fist one never worked out of the box. Unbelievable
por
mine
My Frigidaire microwave did the same thing. My side by side fridge is also Frigidaire, and I had to replace the board twice......no more of their products for me.
por
Switch contacts in the latching mechanisms can fail or become intermittent. Printed circuit boards behind touch pads can flex causing printed circuits to develop cracks over time, resulting in the same type of failures. These include no heating or ventilation fan or intermittent operation, running with door open, etc. Hard to find or fix sometimes, usually it's poor design.
Pontuação 1
I was electrocuted when I was younger, they said I was clinicly dead for 45 min before they brought me back, and I literally did not fully wake up until the middle of the next week! The smell of burnt human flesh, and the excruciating pain should be more than enough to reason to stay away from high voltage unless you are properly trained in it. I still work with electronics and electricity but mostly low voltage projects.
Pontuação 1
I understand, no power at all. Check the fuse in plug (in UK we have), check the fuse in the microwave oven, placed above fan.
If find blown fuse, check appliance for short circuits.
Working with microwave oven is dangerous.
Pontuação 1
There is high voltage fuse between transformer and magnetron.
Fuse can be fitted on transformer in black tube, or next to the transformer in white tube.
Fuse required 750mA - 900mA5kV, mA depends on power of microwave oven.
First thing to check if microwave oven not warming up food.
Failed rectifier will cause to burn main fuse.
http://bargains-zone.co.uk/en/small-elec...
Pontuação 1
Take it to professional don't attempt yourself you can get seriously injured or worse.
Pontuação 1
M y microwave don’t heat water touch. Pad light up the turntable turn but won’t heat the water it is a ge model # jmv7195sk3ss
Pontuação 1
1 comentário:
Whether it is a GE or not, all microwaves are built bascially the same. The most common problem and cheapest fix will be that one of the 3 or 4 microswitches in the door are not functioning anymore. I had the same problem. Pad is lit, turntable works, light is on inside but no heat. One of the switches that the closed door accuates failed. The one that allowed power to go to the transformer. These are safety switches that don't allow the microwave to put out harmful waves while the door is open. So, it thinks the door is still open, but other switshes are saying it is ok to run. All switches must agree. This video helped me troubleshoot. https://www.youtube.com/watch?v=t1tdj3On...
por
i'm a general fix it (computer and sort of general handy) guy my microwave stopped working no power no nothing i looked up on the we bthe most is $3.00 fuse i don't mind buying a $3.00 fuse if it's going to fix the 100.00 microwave otherwise that's it's far i'm gonna go otherwise i'll just buy another not worth the electrocution.
Pontuação 0
Have had this happen to my microwave. What I found was the door switch is not actuating correctly. When it happens, if I pull up a little on the door, while the door is closed, it runs correctly. My micro is around 11 years old.
Pontuação 0
Try to heat with different temperature means change heating temperature after some gap.
Its works for me.
Pontuação 0
I slammed the door shut instead of just shutting it. Then it worked.
Pontuação 0
hello iam not sure but it could be you need a new pad.. that is not worth to fix it is better to scrap the oven and buy a new 1 on amazon,.
Pontuação 0
4 comentários:
Ive done some work on appliances and usually 3/4 of the time its the fuse that blows Mike
por
My 10 yr old Electrolux stopped working several times. Instead of shelling out another $500, I decided to fix it. Both times I didn't have to look any further than the door's micro switches. Mine has 4 switches. One normally closed and 3 normally opened. These wear out from constant opening, closing and slamming. If it works sometimes when you slam the door, or by pushing a little on it, then that's a sure sign of switch failure. All 3 or 4 switches must be engaged before power is allowed to go to the transformer. I paid $6.88 for (2) D3V-16G-3C25 Frigidaire replacements (normally open) on Ebay. The dealer wanted $37 just for one. You'll have to remove sheet metal housing. Switches should be in one area, bottom right if door swings open right to left. Here's an in depth video that should help, but you will most likely only need the ohm meter to test switches and go no further. I didn't even need the meter the first time. That switch was visibly fried. https://www.youtube.com/watch?v=t1tdj3On...
por
@John Last Fixing the reason for the fuse blowing will stop is blowing again. As for chucking out an appliance and not bothering to fix it, that is what most people do, but fixing in saves a lot of money and a lot of raw materials. The microwave in the video was an expensive one, being dual oven, so it was a lot cheaper to fix it in parts costs. It is still working now in April 2020.
por
I have whirlpool magic cook 25 C microwave but won't able to stop my timer if mistakenly i have put 2 min timer instead of 1 min..how to stop it
por
The most common problem is high voltage fuse placed nearby or on the high voltage transformer.
Pontuação 0
Adicionar a sua resposta
Mike será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 30
Últimos 7 dias: 269
Últimos 30 dias: 1,175
Duração total: 824,036
