The Toshiba 40PB200 is a 40-inch flatscreen television in the PB200 series. It was released in 2012.
Wanda dantzler @wandadantzler65
Rep: 1
Postado: 18 de mar de 2019
No sound on TV everything else works best
Esta é uma boa pergunta?
2 comentários:
My sound is out in tv but every thing else works
18 de mar de 2019 por Wanda dantzler
Hi @wandadantzler65 ,
What is the model number of the TV if it is not a Toshiba LED TV 40PB200?
Has the sound worked OK before?
What is the signal source connected to on the TV, coax input, HDMI input, component video input?
If the signal source is from a "box" can you try a different connection type to check if audio is present, e.g. if HDMI now change to component video?
If the signal source is from a "box" can you try connecting it to another TV to prove that it is OK?
Have you checked the sound settings in the menu area?
What have you tried?
19 de mar de 2019 por jayeff
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 15
por Wanda dantzler
por jayeff
