Ir para o conteúdo principal
O PlayStation 3 Slim é a segunda versão do console PS3 com o primeiro número de modelo sendo CECH-2000. Produzido pela Sony Computer Entertainment, ele corrigiu muitos problemas da primeira versão do PlayStation (Fat). O Slim foi lançado no dia 1 de setembro de 2009.
465 Perguntas Visualizar todos
PS3 not start after reflow of bluetooth/wifi chip
Hi, my bluetooth was not working so i tryed this tutorial about reflow the bluetooth/wifi chip of a PS3 slim using flux liquid and a hair dryer for the warm air.
https://www.youtube.com/watch?v=GppwrmXM...
After I did it, the ps3 is not starting. When i connect the ps3 to the energy, the red light is on, but it takes some time to get on. Then, when i press the start button, the light get’s green for a second and the cooler starts to rotate, but then, after a second it stops and the light puts off. Then, after some time it puts red again, and puts off again. The start button does not work at this moment. If i dissconnect the ps3 from the energy and connect again it’s the same, i can start the ps3 and the green light and the cooler are on for one second, after that they stops.
Maybe i broke the connector of the powe supply when warming the chip with the hair dryer? the chip is very near of the power supply connector.
Maybe the flux liquid has broken something? i putted too much liquid and it spreaded on the motherboard.
Exists a solution for this?
thank you.
PD: after giving a little more of warm air and mounting the full console now even the red light isn’t putting red when i connect it to the energy…
Esta é uma boa pergunta?
Pontuação 0
3 comentários
it's kind of the risk you take when you try to reflow a chip using a hairdryer and a youtube tutorial. It's likely that you reflowed several nearby chips/components ...
por
@pollytintop it is possible to know which component is broken? a proffessional whould disscover it and solve it for less than the price of the console? or can i throw it to the garbage?
por
A hair dryer doesn't have anywhere near the heat you would need to reflow anything. What the guy in the video is using is called a hot air rework station. They cost hundreds of dollars for decent ones and have temperature ranges of ~100c - ~500c or ~212f - 930f.
por
Adicionar um comentário
1 resposta
Solução escolhida
PlayStation 3 Wi-Fi/Bluetooth Board Replacement
$29.99 seems like a bargain to me and might just fix the problem for you if this is the board you have been trying to reflow. The other idea would be to go back and check all of your connections are correct.
Esta resposta foi útil?
Pontuação 1
3 comentários:
Playstation slim has an onboard chip that takes care of the bluetooth and the wifi. The link you posted is for a original phat model. And thus doesnt apply
por
This helps the smaller percentage of people with this issue since it only covers the first generation models as Sepp said. The slims need a hot air rework station to replace and decent ones will cost hundreds of dollars. You need a lot of heat, more than 2x what a normal hair dryer can provide.
por
I have the exact same issue here and it is ps3 fat japanese silver which is different from black ps3 fat
por
Adicionar a sua resposta
Pablo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 24
Duração total: 3,191
