Ir para o conteúdo principal
Camera problem after screen replacement
Hi!
I replaced the screen for iPhone 6s plus. Now the cameras arent working. If I havent plugged the front camera connection in, then the both cameras are black. If I disconnect the front camera the rear camera starts working fine.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
If rear cam works after disconnecting front cam then you’ll need to replace the front camera assembly. Most likely due to a torn flex.
Substituição do conjunto da câmera FaceTime e sensores do iPhone 6s Plus
iPhone 6s Plus Front Camera and Sensor Cable
Imagem de Replace a front camera and sensor cable compatible with the iPhone 6s Plus. Includes the front camera, secondary microphone, ambient light and proximity sensors. Part #821-00153-A.
Produto
$55.99
Esta resposta foi útil?
Pontuação 0
1 comentário:
So you think this is not a board issue? Will 6s camera work, I have one laying around?
por
Most likely you damaged the front camera assembly during the repair. This can be a hard piece to remove if you don’t have a lot of experience. Did you just pull it off the old screen? In the future, a little heat will help loosen the adhesive.
Pontuação 0
Adicionar a sua resposta
Lauri Pahkala será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 177
