Ir para o conteúdo principal
An audio/video receiver (AVR or home audio receiver) is a consumer electronics component used in home theaters that convert signals into sound.
280 Perguntas Visualizar todos
Can anyone help me identify these components?
I have a vintage Sherwood receiver and I need to replace a few components. I don’t want to pay $20 for the hand drawn schematics , I know what needs to be replaced I just cant find any info on the components.
both are three terminal
One labeled MSPS 4199 (some kind of transistor?)
One is labeled S2103
Pictures attached
Esta é uma boa pergunta?
Pontuação 0
2 comentários
I looked for these numbers in Mouser but did not get a match. The S2103 looks to have 4 pins and where it is located seems to be related to the power supply, if so then a guess is it is a diode bridge.
The other component looks like a transistor, but do not know the type.
por
The MSPS 4199 is an old Motorola SPS transistor, Motorola SPS became Freescale Semiconductor which became NXP. This stuff is vintage, I haven't known mouser to carry a versatile selection of vintage stuff. By the pcb it may appear at first sight to be 4 pin, but i assure you it is 3 pin. You are correct about it being a power supply.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Aaron it will help if you can tell us the exact model of your receiver. The MSPS4199 is actually a Motorola SPS4199 and an equivalent for that would be a 2N4401 NPN Transistor - NTE123AP
As for the other component, a view of the complete PCB may help us further. It appears as it has been manufactured by Fairchild
Update (03/13/2019)
Okay now we know this is reference designator Q205 (identical to Q305) and we know it is a Fairchild S2103 NPN transistor. I do not yet have a vintage catalog from Fairchild to find an equivalent, but have the schematic with the voltage on BCE of the transistor
Esta resposta foi útil?
Pontuação 3
2 comentários:
The Receiver is a Sherwood S-8500, it is a Fairchild component. I believe the FC component has the number 834 on it as well.
por
A 2N834 might just work for that.
Type Designator: 2N834
Material of Transistor: Si
Polarity: NPN
Maximum Collector Power Dissipation (Pc): 0.3 W
Maximum Collector-Base Voltage |Vcb|: 40 V
Maximum Collector-Emitter Voltage |Vce|: 30 V
Maximum Emitter-Base Voltage |Veb|: 5 V
Maximum Collector Current |Ic max|: 0.2 A
Max. Operating Junction Temperature (Tj): 200 °C
Transition Frequency (ft): 350 MHz
Collector Capacitance (Cc): 4 pF
Forward Current Transfer Ratio (hFE), MIN: 25
Noise Figure, dB: -
por
The MSPS 4199 is a transistor. The other I think is another transistor but I’m not entirely sure.
Pontuação 0
Adicionar a sua resposta
Aaron será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 78
