Ir para o conteúdo principal
Released in March 2017, the G6 is LG's flagship phone running Android 7.0. This device is available across all major wireless carriers. Physical repair of this device may eliminate water resistance and cause the device to be vulnerable to water damage.
Adhesive slowly falling off after back replacement
I recently replaced the back of my lg g6, and after about a week, the back has started to go farther away from my phone. I used 2 layers of 3m 3mm adhesive tape, and it was on very firmly at first. What did i do wrong? How can I prevent this from happening
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Try using b-7000 glue instead. It's like a rubber type glue and easy to remove. Just make sure you don't get it near cameras or speakers
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
spoons será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 143
