Power steering leaking on driver side
I have a 2001 grand caravan, I’ve have it wrk on ,put on a pump…it still has probs..took it backto shop, bcz of my reservoir losing fluid..they took it in claim tighten stuff..it still leaks. asked up front if they check hoses to make sure they were good.. oh yes… I knew then they we’re lying.. I live small town can’t find honest mechanic.. being woman they take advantage.. getting to point..
it started to squeling more n and hard to turn and winter time and rain seems worst.. I just keep putting in fluid w stop leak and Helped temp…today I was driving it made strange noise differently, it cold here. thought it was something else., I pushed on the gas n heard pop sound.
I got to gas station no fluid. I added some till, I get home …u could hear gurgling sounds from reservoir, ik that air in line.. leak is so bad bcz, when I was leaving gas station it had big puddle of fluid, I got home the fluid left streaks on road.
I let it sit then pour more fluid in and turned it on & got under the car as far I could , on the right side toward middle not in middle but not by tire..It making louder noise n gurgling.. I hope this doesn’t tear up the pump.. read symptoms for rack n pinion , don’t have any of them symptoms.. , I feel like it a hose from reservoir, Idk… I have pic 1 is on side where leak is around 2 pic is front of car.. they pics came backwards sorry….
.. I really appreciate any help thank you…
Esta é uma boa pergunta?
1 comentário
See u pic it showing pump n high end.. do u have pic of rack n pinion and lines that run from the reservoir down under? Replacing the low hose do u have be under car can u do thru top? Sorry to ask but vans are very cramp not room to see stuff compare to other cars I owned like Taurus or Camaro...
por Angie D
