How to remove the cover plate?
Hello,
is there a tool or a trick to remove the cover plate.
It is too slippy to make it rotate counter clockwize by hand.
Thank you
Esta é uma boa pergunta?
Hello,
Thank you
I had the same problem. I cut a length of duct tape, about 20cm long, cut it down the middle, stuck it crosswise onto the cover plate (taking care not to stick it to anything else) then tugged on the free ends in an anti-clockwise motion while pressing the plate inwards. Success!
Esta resposta foi útil?
Wow -- I've been trying to get the cover plate off forever without success. Your solution worked for me on the first try! Thank you for posting this solution.
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 21
Ao todo: 762
