Ir para o conteúdo principal
Model A1419 / EMC 2806 / Late 2014 or Mid 2015. 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (ID iMac15,1); EMC 2834 late 2015 / 3.3 or 3.5 GHz Core i5 or 4.0 GHz Core i7 (iMac17,1) All with Retina 5K displays
What is the display connector part on a late-2015 iMac?
I have a late-2015 iMac 5k with a broken display. It looks like the previous owner broke a couple pins on the logic board connector based on the couple missing pins on the original LVDS cable. Even when I connect a working display using a new cable it doesn’t function.
It’s not the display or the cable as I’ve tried both on another iMac 5K.
I’ve seen this (the logic board connector) referred to as a LVDS or a special eDP connector.
*Where can I buy this? And can I find someone to solder/replace it for me?
I’ve also tried reseating the cables with no luck. Is there something else I could try?
It’s one of the i7 models with m395x. I’d hate to junk it.
Esta é uma boa pergunta?
Pontuação 0
6 comentários
@dieselm if you can give you your Mac Model No. or SN I can link you to the replacement Logic Board.
por
I'm going to take a wild guess and say its an A1419 "Core i7" 4.0 27-Inch. If this is the case, here's the part:
iMac Intel 27" EMC 2806 Logic Board
por
I'd rather not replace the whole logic board. Can anyone identify the connector part on the logic board?
por
Don't guess! Look on the bottom of the stand, get the serial number, plug it in here and tell us EXACTY what machine you have. We can then better advise you.
https://everymac.com/ultimate-mac-lookup...
por
emc 2834, a1419. iMac 17,1
por
Exibir mais 1 comentário
Adicionar um comentário
4 respostas
Solução escolhida
OK, now that we know what you have, i.e., an EMC 2834
There are three machines that carry that designation
Your machine is one of them. Processors run from a Core i5 3.2 GHz, or i5 3.3 GHz or a Core i7 4.0
Your serial number should have told you which one it is.
Since you said it has the M395X sounds like you have the high end machine
In this case it is well worth getting the connector replaced.
This connector is easily damaged when removing the cable incorrectly. Personally I use two people when connecting or disconnecting it. One to hold it open so the screen doesn’t drop and rip the cable out and the other (smaller person with smaller hands to actually remove or insert the cable).
Here’s a pretty good video on how it’s done:
https://www.youtube.com/watch?v=48tyy6oM...
Esta resposta foi útil?
Pontuação 4
The website is called ifixit and not iswappedit. So people should really focus on what was asked. The OP asked about the replacement connector. Of course he is fully aware that replacing the logic board will solve the problem but he would rather not chuck 350 at a 2nd hand logic board when the connector usually cost 5-10. Also this planet can do with less waste.. so we should really try and repair these things.
On topic, we have done few in our shop but could never find the actual connector sold separate. We usually salvage connectors from other boards that have other damage that is not repairable. It is an easy job though for anyone that has the right tools, should not take longer than 10 mins so it’s well worth it if you can find a donor board.
If I find the actual connector I will repost.
EDIT:
Boom. Though I will have one more look on Aliexpress and there is finally 1 seller that has them.
https://www.aliexpress.com/item/32841236...
Just ordered some for myself. Happy soldering!
Pontuação 1
3 comentários:
You have a bad link!
I had posted the maker in the original post I-PEX Connectors contact them for information of a local supplier!
I'm lucky! I have a couple of great suppliers who I get my parts locally. Not everyone has access so the cost of shipping then effects the cost.
por
Yes we did. The link in my post was where I got them from but I see that the listing is now down. I will have a look to see if the seller listed the connectors elsewhere and repost.
The iMac that came to us was experiencing no display symptoms. Chimed and worked on external but there was no image or backlight. The previous repairer used the wrong adhesive for the LCD after charging the HDD and the display fell off pulling the connectors out but somehow not damaging the board connectors (at least on the surface) . The diagnostic LEDs on the MLB were showing 1st LED on 2nd LED was half power lit after the chime and 3rd was off. Initially as the initial inspection was not showing any visible damage to the connector we have tested with a new display and with a new display flex with no joy.
After we replaced the connector all was well and the iMac passed all the tests.
Hope this helps someone with your diagnostic.
I will repost once I find the listing again.
por
Here's the current listing of the connector:
por
@dieselm
If you already tried using a working display and cable, it’s clearly the LVDS connection port on the logic board itself. Especially if you tried them on another 5K.
The only other option would be to replace the logic board.
Getting someone to repair the board for you will probably cost just as much as buying a brand new board. The only time you might consider going this route is if the board costs $1000+ to replace, in which case you’ll have to find a Mac Tech somewhere.
If this answer helps you, let me know!
-Alex
Pontuação 0
4 comentários:
Thanks! That’s it. I’ve run the machine with an external thunderbolt display and diagnostics. It’s totally functional.
But the CPU will throttle to 800Mhz because the SMC doesn’t see the temperature sensor that’s coming from the display.
I have a friend that’s a tech who can do this type of repair. He needs to know what type of connector this is though.
I guess this quite common on previous iMacs as there are number of videos of techs repairing the LVDS connectors people pull off. Nothing I would try myself.
I believe it’s a 60-in eDP extended LVDS connector which apple used to get 5k working at 60hz. Do you have pointer to where i might able to source this? Or a pointer to what it exactly called.
por
This connector looks denser than the previous ones and on MacBook pros.
por
Not too sure how they compare to the MBPs. If you're determined to have your friend repair the connector, I'll tag two guys that know more than me on this kind of stuff. Although, if he's sure he can do the repair, I would hope he would know what kind of connector it is... Beyond me, but I would replace the board. @danj @mayer
por
Here's the source of the connector I-PEX Connectors
por
Did you ever find this LVDS connection?
Pontuação 0
Adicionar a sua resposta
Diesel mcfadden será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 9
Ao todo: 2,162
