Ir para o conteúdo principal
Model A1502 / 2.6 GHz (Turbo Boost up to 3.1 GHz) or 2.8 GHz (Turbo Boost up to 3.3 GHz) dual-core Intel Core i7 processor with 4MB shared L3 cache.
494 Perguntas Visualizar todos
Cant find hard drive in Disk Utility
Macbook wont boot and hard drive cant be seen in disk utility. Please help
Esta é uma boa pergunta?
Pontuação 2
7 comentários:
Hey Anthony. The solution could be a number of things. Have you tried entering MacOS recovery already?
Press and hold Command (⌘)-R during startup. Let me know if you're able to enter the recovery suite like this.
-Alex
por
@tony3000 any luck with that?
por
I was able to open the disk utility but could not find my hard drive/start up disk
por
In MacOS Recovery? Or Target Disk Mode? In other words, on the MBP you're having trouble with?
por
oh opps! now I see where to add a comment. Sorry, new here!
por
Exibir mais 2 comentários
Adicionar um comentário
2 respostas
I don’t have an answer, but just last night I attempted to use a trial of CCC and I drag & dropped my HHD from finder to the source box and POOF,
now I have to hunt for it.
Great question & await
Update (05/06/2021)
When you are in Disk Utility
on the top bar: click view,
select “show all devices”
? For years when I was in Disk Utility I never even knew that top bar was up there!!! So many hidden in my face gems…
Esta resposta foi útil?
Pontuação 0
this is the disk utility and my start up disk can’t be found
Pontuação 0
Adicionar a sua resposta
Anthony Johnson será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 438
