iPhone X screen is frozen
I just had my screen replaced 2 Friday´s ago, I dropped my phone again. The screen has been working fine but I just updated my phone and now my screen wont work at all. What do I do?
Esta é uma boa pergunta?
Selected when a check mark is present.
Located in the upper-left.
If passcode is already turned on, enter the passcode then skip to step 8.
When turned on, access is allowed when the screen is locked.
When turned on, all data on device is erased after 10 failed passcode attempts.
Esta resposta foi útil?
It could be because of the new update has “locked’ the phones screen because it was a 3rd party screen and not a “apple screen”. I have seen it happen too many times. If the screen is not cracked, take it back to where it was replaced and have them swap it out with another screen and make sure it works.
sometimes if the screen is a poor quality, any single drop will cause it to become unresponsive
Repair iOS system is a way to fix the iPhone X screen frozen problem. If you're looking for the best iOS System recovery tool, you can check here.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 2,437
