Ir para o conteúdo principal
LG's flagship smartphone, with a unique slide-out battery and detachable I/O module supporting multiple hardware expansion options. Released in April 2016.
Is it possible to replace a contact spring on Motherboard?
Hi:
I received an LG G5 model VS987 phone. It was reported the power button did not function but on closer inspection I found 3 contact springs on the motherboard that are broken- these connect with the power button on the back panel. I have safely removed the 3 broken contact springs, and removed three good ones from another motherboard for replacements. But, how can I safely solder the new contacts to the good motherboard? Anyone done this already?
Thanks!
Tom
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Thanks for your input…
Actually I`ve started researching SMD rework stations (uses hot air), that is how I will go. All this is still a bit new to me.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Just use good tweezers and hot air at about 450c should do the
Esta resposta foi útil?
Pontuação 1
1 comentário:
Is there a video you can post on where the motherboard is broken? I have the same issue with my power button which I've already replaced yet it is still not working.
por
Adicionar a sua resposta
Tom será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 292
