Ir para o conteúdo principal
Post battery replacement charging problem
Hello, I replaced the battery in an IPhone 6S last night. I followed the instructions by discharging below 10% and charged the phone overnight. The level of charge displayed never got above 28% now it seems to jump up and down and the phone resets itself frequently.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
By seeing this might be battery not properly connected on battery connector.Check it first if the problem still same try to replace battery with new one.
Esta resposta foi útil?
Pontuação 0
1 comentário:
I've checked the connector again. It seem to be firmly snapped into place. If this is a defective battery how does ifixit handle that.
por
I suppose you did everything the right way? You did shut down the iPhone before opening it and getting in there with a screwdriver?
Pontuação 0
Thanks for the suggestions. It was a faulty battery. I was able to install the original one as a stop gap until I get a replacement. It wasn’t holding a charge well before the replacement but it’s functional.
Pontuação 0
Adicionar a sua resposta
tyheel17 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 13
Ao todo: 135
