Ir para o conteúdo principal
A Touchscreen Notebook that was created by HP in 2014 for computing and processing.
6 Perguntas Visualizar todos
Black screen when playing videos
Hello, my computer goes black screen every time I play videos on YT or try to watch netflix, taskbar still shows and as soon as I move the mouse y goes back to the video but won’t stop turning black. Also tried to open some photos from my library and error -2147219194 showed up, I don’t know if thats related, Thanks for the help!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
From doing a little research I can suggest doing a few things. Restarting Windows file explorer is my first suggestion. A lot of problems with the taskbar is caused by windows explorer. This can be done with the following steps:
  1. Open file explorer
  2. Hit Control+Alt+Delete and select Task Manager
  3. Navigate through the Processes tab of task manager until you find a process called Windows Explorer
  4. Right click on it and click Restart
  5. Wait a few moments and try Youtube, Netflix, or opening a photo after your taskbar reappears
My second recommendation is to restart your computer use Windows in “safe mode”. This mode boots Windows with only programs necessary for operation. A guide from Microsoft on how to do this can be found here. After booting into safe mode, then you can try to open a photo or watch Youtube/Netflix. Hopefully the first one works. If the second one helps let me know so that problem can be troubleshooted further.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Pablo Garcia será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 73
