Ir para o conteúdo principal
Apple's 6th revision to the iPod Touch lineup, released in July 2015.
149 Perguntas Visualizar todos
Why are there vertical lines running down my screen?
I recently replaced the screen on my iPod Touch 6th generation. After I put it back together and turned it on, there were vertical lines running down the screen. I followed the instructions carefully and made sure all the cables were plugged back in. Any ideas what I did wrong?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Hello!
Two possibilities: either the replacmeent screen you’ve used is damaged, or the logic board was damaged in the process. Provided that you’ve ensured all connectors are seated properly, you may want to attempt to put the original screen on if it might give you a better idea of what component is faulty.
Good luck!
Esta resposta foi útil?
Pontuação 2
I dropped my iPod when I was standing up, and when I picked it up there was vertical lines on my screen. My iPod will not turn on. How do I solve this problem?
Pontuação 0
1 comentário:
Have you tried holding down the power button and the home button? If that doesn't work, try to connect your iPod to iTunes on your computer to see if that does the trick.
por
Adicionar a sua resposta
Jason D será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 12
Duração total: 3,804
