Ir para o conteúdo principal
Um tablet de 10,1 polegadas da Samsung com processador de 1,4 GHz, tela LCD de 1280x800 pixels e display multitoque de 149 ppi. O número de modelo do dispositivo é GT-N8013ZW. Lançado em agosto de 2012, o reparo deste dispositivo é simples.
2012 Samsung Galaxy Note 10.1 with slow charging issue
I cannot seem to get this device to charge at a decent rate. When plugged in, it only pulls 0.83 A at 5.65 V. I have installed a new battery and have also reset the device, several times, each time it works marginally better for a while, then back to slow charging issues again. I have tried several different Samsung charging units and cords, all with the same outcome, slow charging.
Should I be looking for a deeper issue?
Thanks for your help.
JK
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
If you have done all the steps like changing battery and resetting. It seems more like a motherboard level issue instead of a battery / charging cable issue
Esta resposta foi útil?
Pontuação 0
I find that a lot of the time the battery is “Below voltage” You will to connect a power supply directly to the battery pins in order to boost it to a level it will charge, Plenty of guides on how to do this
Pontuação 0
Adicionar a sua resposta
J.K será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 28
Ao todo: 2,217
