Ir para o conteúdo principal
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Perguntas Visualizar todos
I got an iPhone 7 plus red. What model is it?
I got an iPhone 7 plus. What model is it?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Are you asking about (Product) RED Which is a special product program Apple runs to support AIDS support & research.
Other than the case color is it no different from the standard product.
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Depends what carrier you’re on, which would determine the model. There are three models of the iPhone 7 Plus:
  • A1661 - GSM & CDMA Model (On Sprint and Verizon) or on AT&T if you bought it at Best Buy
  • A1784 - GSM (T-Mobile & AT&T) or if you bought an unlocked device at the apple store
  • A1785 - This is the Japanese only model which specifically supports cashless payment systems in Japan
To check:
  1. Look on the lower back of your iPhone, which should list the model number at the end of the first line of text.
  2. Otherwise, go to Settings > General > About. To the right of “Model,'“ you'll see the part number. To see the model number, tap the part number. Your model number will be revealed.
Reference the Apple article for further info: https://support.apple.com/en-us/HT208200
Let me know if this helps!
-Alex
Esta resposta foi útil?
Pontuação 3
Check on the back there should be a model number starting with A
or in the setting-general-about
Pontuação 2
Adicionar a sua resposta
Joshua será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 49
