Ir para o conteúdo principal
O Xiaomi Mi A2 (também conhecido globalmente como Mi 6X) foi lançado pela Xiaomi em julho de 2018 em várias configurações de memória interna. Ele faz parte do programa Android One, que garante atualizações por dois anos.
Backlight only works during startup
I recently changed the screen on a Xiaomi Mi A2 Lite. When I start the phone up, the Android One logo displays with full brightness and colour without any issues.
The problem is that once the phone turns on there is no backlight. You can still see the display if you are in a dark room and everything seems to show correctly. I have tried updating and factory resetting but still having the same problem.
Any advice would be much appreciated.
Esta é uma boa pergunta?
Pontuação 1
3 comentários:
Did you ever find an answer to this issue? My phone developed the same problem yesterday.
por
I have the same problem with a replacement screen. Did you find any solution?
por
Have you found what was causing this?
I’ve the same issue, replaced the lcd on a xiaomi mi a1 and the backlight is present at the logo startup but completely black after that.
On a dark room I can barely see the screen and all it’s working, but adaptive light button is missing, seems like the bootloader is able to use the backlight but not android itself
por
Adicionar um comentário
1 resposta
I’d try to disable the “adaptive brightness” feature under settings->display, but I highly doubt that this can solve an issue like this.
On the software side there should be restrictions in place to how dim the screen can get and I’ve never even heard of the software having the permission to turn the backlight off.
The only suggestion then would be to replace the screen, but since the backlight is working upon boot…
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Ryan Storey será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 22
Ao todo: 1,373
