How to repair the flash latch not locking
he flash latch need to be fixed, as it does not stay down
Esta é uma boa pergunta?
I believe that this is caused by a little plastic hook that holds the in-built flash is broken. If you do a Google search, you will find that this is a very common error. There is an interesting write up about the repair of one of those on a D90 which is essentially the same flash unit. Just in case you do not have it here is the service manual for that camera. Good Luck
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 1,690
