Ir para o conteúdo principal
Informações de reparo, guias de serviço e ajuda para resolução de problemas de geladeiras fabricadas pela Frigidaire.
Frigidaire FPRH19D7LF1 leaking water from the inside
My Frigidaire FPRH19D7LF1 is leaking water from the inside & it pools up below the bottom shelf, before dripping out onto the floor in front.
  • What’s my problem?
  • How do I fix it?
  • Thanks
Esta é uma boa pergunta?
Pontuação 1
3 comentários
I have the exact same refrigerator w/ exact same issue (also sold as an Electrolux, made by them I believe)
por Compartilhar
Just got my fridge a week ago. When I hooked up the water supply line and went to dispense some water instead of coming out of the dispenser it was running on to my floor from the bottom left corner of the door. Has anyone else ever had this problem and how do I fix it
por Compartilhar
@jeremyprussell
What is the full model number of the refrigerator?
If the refrigerator is still covered by the manufacturer's warranty, contact the manufacturer's service centre in your location to get them to fix it so as to not void the warranty by trying to fix it yourself.
If it's no longer under warranty it sounds like the hose connection between the main water inlet solenoid valve and the dispenser valve has come adrift somehow.
As I said above knowing the model number will help
por Compartilhar
Adicionar um comentário
1 resposta
Solução escolhida
Hi @dblmed ,
There may be a problem with the freezer drain tube or drain screen being blocked.
Here’s a link to the parts for your refrigerator to help locate the freezer drain.
Type “drain” in the search box (next to Parts diagram (3) in the centre of the page), press Enter and then click on the “Cabinet” parts diagram which will show 4 parts with drain in their description
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
David Landers será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 29
Ao todo: 5,367
