Ir para o conteúdo principal
A soldagem é um método de conectar duas peças de metal, derretendo um metal de preenchimento entre elas. Existem muitos tipos de soldagem, mas este artigo foi criado para ensinar a você o básico da soldagem eletrônica.
Micro soldering start up
Hey all I am hoping there is someone out there who may be able to help me.
Recently I have been doing some research into micro soldering and would like to give it ago.
What equipment should i look at getting and what do I need to take into account.
Any advice would be great .
Thank you
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Jessa Jones created a set of vids with IFIXIT a few years ago which are very informative! Here’s the first in the series Microsoldering with Jessa Jones.
Theres a lot to it! Between getting the correct gear, you need the skills to read and understand schematics and lastly access to the needed SMT components.
And lastly practice! Lots of it!
Esta resposta foi útil?
Pontuação 4
2 comentários:
Thank you very much for this very appreciated.
por
Yea .... Dan hit the correct word.... practice made perfect :D
por
Hi claytonrablin
As for me, I had a Hot air SMD rework station and a temperature controlled soldering station.
Some would say for temperature controlled station, minimum 60W and above.
I prefer those stations to be separated, in event of a failure which will brick all usage. Encountered once when my temperature controlled soldering station heating element is bad. Lucky having the hot air, which is needed to solder the new heating element to the soldering iron.
Get good flux, desoldering pumps, etc.
A good start.. .Louis Rossmann videos...
https://www.youtube.com/watch?v=bVoBZqlv...
Update (01/20/2019)
Thankyou very much for this fantastic advice. What did you start off soldering ?
Update (01/20/2019)
Hi claytonrablin
Replacing QFP ethernet chip
Pontuação 4
Adicionar a sua resposta
claytonrablin será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 35
Ao todo: 769
