Ir para o conteúdo principal
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 Perguntas Visualizar todos
Late 2013 iMac (27") screen hinge replacement
Does the iFixit forum have their own version of a full step-by-step guide to fixing the broken hinge issue with the late 2013 27” iMacs? I am not looking for a machack fix where you are required to fit an additional clamp between the screen and the stand. I would like to fix the hinge so that the tilt can operate as it should. But at the same time, I do not want to take it to Apple only to be charged an exorbitant price.
Thank you guys!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
The steps are the same as taking the logic board out. Review this IFIXIT guide iMac Intel 27" EMC 2639 Logic Board Replacement once you get to that point you can see the hinge which is just behind it
Take the foot stand off (nine screws) as well as the stand and then take the hinge its self off. The replacement hinge info: The Book Yard UK - Mac 27" Hinge/Clutch Mechanism (12/13) Apple P/N 923-00151
Esta resposta foi útil?
Pontuação 2
And just to add there is no need to replace the entire mechanism, the issue is caused by the rubbish plastic washers that secure the end of the spring mechanism. You can replace these with metal ones to fix the issue and prevent it recurring.
Pontuação 1
I used a coil from old logic board…
Pontuação 0
Adicionar a sua resposta
Wayne H será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 26
Duração total: 4,051
