Ir para o conteúdo principal
Guias de reparo e suporte para o OnePlus 5T, um smartphone Android com um display AMOLED de 6,01". Lançado em novembro de 2017. Sucessor do OnePlus 5. Número do modelo: A5010.
Issues with screen after replacing
Hello,
I'm experiencing some issues after replacing my screen. I'm getting a lot of ghost touches when scrolling, and every few days the screen goes crazy with clicks. Completely unusable. Can't do anything but hard reboot which fixes it. The Keyboard is a bit off. Most gestures work, but only if you use a different one each time. Example: You can't use 'V' twice in a row. You have to do a different gesture each time or it won't respond. Music gestures don't work at all.
Everything else works as it should.
Any idea what could be causing it?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Probably needs the digitizer cable reset. Desmontagem analítica do OnePlus 5T here is the tear down video if you feel like doing it yourself. The LCD able is around 3:43. If that doesn’t do it it is probably an issue with the motherboard connector or the LCD connector itself. My guess would be that it is not seated properly.
Esta resposta foi útil?
Pontuação 0
Original screen folder Amoled
Pontuação 0
Adicionar a sua resposta
Liam Mooney será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Ao todo: 1,997
