Ir para o conteúdo principal
iPad Air Wi-Fi + Cellular, model no. A1475. Available in Space Gray or Silver, with 16/32/64/128 GB configurations.
125 Perguntas Visualizar todos
Should I remove this coating on the LCD?
Hi,
I am replacing my front panel on iPad using the ifixit guide. There is this foam found on the outside border of the LCD. Should I remove this? I afraid to remove it since it might somehow interfere with the digitalizer.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
Foam is there to stay, do not try to remove it, it will be covered by the top glass frame and you won’t notice it once it’s mounted in place.
Esta resposta foi útil?
Pontuação 3
This is the dust proofing foam gasket. It is torn when you disassemble the device and NOBODY on the internet seem to sell any kind of replacement, so keep what you have as much as possible.
Pontuação 2
2 comentários:
UnionRepair seems to carry them now.
por
Doesn’t look like the original part or design, just generic foam tape.
por
Adicionar a sua resposta
Ronald será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 69
