Ir para o conteúdo principal
Repair guides for the Samsung J7 Pro. Learn how to repair your Samsung J7 Pro on your own.
How to recover deleted photos from Samsung galaxy J7
How to recover deleted photos from Samsung Galaxy J7? All photos on my phone are deleted by system error. How to recover them? Pls help.
Esta é uma boa pergunta?
Pontuação 7
5 comentários
Someone has theft my old phone samsung j7 in tirupathi November 19th 2019. I want my old photos, videos in the Samsung phone pls help me . How can I recover all the data in my old phone pls answe
por
I deleted my photos on my galaxy J7. How do I recover without a computer
por
Need to get my photos back on my phone
por
How to recover permanently deleted photo of Samsung j7
por
@sajansewa2
If there is no backup, you may need a professional data recovery app for Android to scan the device memory to see wether you can find wanted data from the results.
por
Adicionar um comentário
4 respostas
Pergunta mais útil
If the deleted photos saved on sd card, first stop using it in case of data overwritten. Then connect your Samsung Galaxy J7 to computer via usb cable. Here, you can use Coolmuster Lab.Fone for Android to scan it. If the deleted photos can be scanned out, you can recover them back easily.
Esta resposta foi útil?
Pontuação 2
2 comentários:
Try out the latest images recovery process in phone samsung galaxy j7
por
If you didn’t have a backup, you can use an Android recovery tool to restore the deleted photos. But you’d better stop writing new data on your Samsung galaxy J7. Good luck.
por
Do you have Google photos sync with your gallery? Or do you have Samsung cloud on and sync?
If not,you can access them from internal storage,the only method is to use some photo recovery program that have method to detect the internal storage.
It is worth mentioning that with you have to make sure that the photo are not overwritten by new files before recovering.
Pontuação 0
Did you save the photos to an inserted SD card? or phone memory?
If SD card, stop adding new files to it, such as stopping taking photos or downloading files. If phone memory, you’d better stop using the phone right now, because new items will be generated when the phone is in use.
Recover photos from SD card
Pontuação 0
EaseUS Data Recovery Wizard Crack may damage your computer. Get the official EaseUS Data Recovery Wizard Crack. EaseUS data can be recovered with a serial number in two ways.
Pontuação 0
Adicionar a sua resposta
roycejane58 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 12,560
