Cube is leaking from the bottom of the unit any suggestions?
The unit in itself still works cooling/heating but it is now leaking from the bottom of the unit doesnt appear to be at the connect hose
Esta é uma boa pergunta?
I would suspect the hose connections as seen in step#5 of this teardown:
ChiliTechnology ChiliCube Teardown
To test use a small artist type brush and use a dishwashing soap and paint it around the connectors. If you get bubbles, you have found where the problem is.
Esta resposta foi útil?
Once you find the leak, how do you fix it?
Seal the crack with a good product like this:
I had to replace one of my Ooler hoses, they look to be food grade silicone. Easily bought at amazon but you have to figure out the size. I used aquarium tubbing to test, the silicone will be in soon.
Últimas 24 horas: 3
Últimos 7 dias: 20
Últimos 30 dias: 116
Duração total: 6,163
