Ir para o conteúdo principal
Released on June 23, 1996, Model NUS-001, 64-bit gaming console
114 Perguntas Visualizar todos
The Ntsc-j N64 has noise and bad quality on Pal TV
Hi, i have a problem with my old japanes nintendo64 that has noise and bad quality on Pal tv screen. the cartridge has inserted in console is "Golden EYE" USA version.
and i must say in past i connected the 110V power supply into 220V!
Sorry for English.
Esta é uma boa pergunta?
Pontuação -1
3 comentários
nobody?
por
Have you tried a different cartridge? Does this happen to all of them? How long has this been going on? Did it work before or is this something that just happened? What is the serial number of your console?
por
Thank you for giving answers
-The issue about some cartridges there are other. and Unfortunately I do not know nothing about the past of this device. The model NO. is "NUS-001(JPN)" and this: "G744618 NUS-JPN".
-"and i must say in past i connected the 110V power supply into 220V!"
oh god! i'm forget to say that after this action, the psu has Bursts!!!
Actually I'm looking for a way to the video system from NTsc to PAL do change. Any modification on the main board or making an ntsc to pal converter or ...
thanks
por
Adicionar um comentário
2 respostas
Pergunta mais útil
The only way to convert your console to NTSC is be means of a converter like Richdave suggest. There is a way of converting "some" of the N64 to RGB by modifying your console. You will have to check more closely on your serial number to make sure that your console is "modable" Here is thetutorial and there are more that tell you more. Oh yes, you should be looking into getting a new PSU as well. Good Luck
Esta resposta foi útil?
Pontuação 2
6 comentários:
Isn't the console already an NTSC with a US game in it?
por
Sorry! Was written wrong, I like to convert the NTSC to PAL.and the psu was repaired too.
Thank you "oldturkey03", I should say my N64 is'nt Modable. I already tried it.
I want to know the device is defective? or according to "Richdave" it related to PAL & NTSC system?
sorry for my english.
por
if the PSU "burst" as you say, then it should be replaced regardless of any other symptom. The description of the video out you describe fits what I have seen with NTSC signal into a PAL TV. That suggests that the console is likely working and needs the correct video signal converter (try eBay) but you need to replace the PSU to be sure.
por
terma, I'd go with what Richdave is suggesting. Not knowing which mods you attempted your best bet would be a converter. Change your PSU and start one thing at the time. What mods did you undertake to get it to RGB? Check this forum for some more help on it.
http://nfggames.com/forum2/index.php?top...
por
Thank you guys.
Rgb case was cancelled entirely. I will try the psu Czech and I'm also looking for a PAL converter.
por
Exibir mais 1 comentário
NTSC and PAL are different TV broadcast standards. You cannot expect that an NTSC signal will be displayed on a PAL TV correctly. You need a converter. eBay has them listed for around $25 - $90.00
If you did plug the PSU into the 220V supply and it was not rated for 220V I'd expect it would not work at all afterwards. Perhaps it is a multi voltage PSU like most modern plug packs.
Pontuação 1
Adicionar a sua resposta
terma será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 5
Duração total: 1,873
