Ir para o conteúdo principal
O C720P é uma atualização com tela sensível ao toque do Acer Chromebook C720.
Slightly Cracked Glass Screen/Interchangability?
I have a question I really hope somebody can answer. I would really like to know if I can replace this with a regular non-touch screen c720 screen?
Imagem
Imagem
If anybody could help me I would really appreciate it?
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
There should be a 4 digit number behind the C720P Can you let me know what that number is? A new screen should be around $55 for that laptop.
por
2625 is the 4 digit number
por
Adicionar um comentário
1 resposta
Unfortunately for your model, there is no “non-touch-screen” version of your display. Also, It does not look like the digitizer is sold separately from the display assembly, so you will have to replace the whole display assembly. I found a fairly affordable display assembly though, and the replacement should be as simple as plugging the LCD in and screwing the hinges in place. You can find the part on eBay here: https://www.ebay.com/itm/Acer-Chromebook...
Esta resposta foi útil?
Pontuação 0
2 comentários:
Please remember to check that this matches you computer, as I only went by the information given in the post.
por
The Acer C720 is the non-touch version of the C720P as far as your variants go. The C720 is going to be a difficult model to find parts for due to the popularity with online school programs. I would check ebay for a C720 or C720P LCD Screen, Bezel and Cover Used. There are lots of kids spilling drinks all over motherboards leaving very usable LCD assemblies for sale.
por
Adicionar a sua resposta
Zachary Neyhart será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 20
Ao todo: 633
