Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
How to fix Eject sensor?
I recently purchased a used ps4 that has an issue with the eject sensor/button. The system reads and ejects discs just fine as long as I do it through the menu. So my issue is just the button or sensor. The power button and sensor work perfectly fine. Does it need a new button or could something be disconnected? Any help would be great!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You most likely have a model where the button is touch sensitive. In this case it’s usually either the metal spring that connects the eject button to the eject daughterboard is broken or bent. If it’s bent the wrong way you can bend it back so that it touches the eject board.
If it’s broken though you’ll need to replace the bottom cover.
Esta resposta foi útil?
Pontuação 3
4 comentários:
That did the trick. Thanks a ton!
por
Thank you very much. Worked 100%.
por
Hello, i have tried this however i cant tell if the bit of metal is touching? Is there a trick or special shape the metal should be?
por
B Wallace I'm wondering the same thing can someone help , I've bent it right down , I'm thinking maybe it's the ribbon connection or something .
por
Adicionar a sua resposta
Christian S. será eternamente grato(a).
Visualizações:
Últimas 24 horas: 5
Últimos 7 dias: 12
Últimos 30 dias: 41
Ao todo: 2,737
