Ir para o conteúdo principal
In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
423 Perguntas Visualizar todos
Spilled a tea on my MacBook keyboard
Hi,
I’ve spilled a tea (no sugar, no milk) on my Mac keyboard. It was 1/3 of 0,4l glass, so not that much. Also, the tea is not that acidic, is it? I immeditally plugged everything off and switched the device off. Then I left it upside down for 24hrs to dry it out and to let the water eventually come out. After that, I took the Mac to the closest Apple store. They did run a diagnosis test and no issue was found, everything just works fine.. However, I was advice to make a repair of a top case with keybord and trackpad - the cost is £300. I have a deadline for my Masters dissertation in two weeks and need to use the laptop.
Could anyone please tell me if I can use it when the diagnostic test has not found any issue? Is there any chance that I’m just a lucky guy and the laptop passed with no damage?
Esta é uma boa pergunta?
Pontuação 1
1 comentário
exact same here, what happened and what did you do? what do you advice me?
por
Adicionar um comentário
1 resposta
Solução escolhida
your better having the logic board cleaned and the keyboard changed as a precaution. corrosion will happen overtime and just because its still working atm doesnt mean it won’t stop working at some point due to the liquid damage
Esta resposta foi útil?
Pontuação 3
1 comentário:
This is the correct answer.
por
Adicionar a sua resposta
Patrik Huber será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 2,393
