Why does my washing machine pour water during the spin cycle?
Overview
My washing machine has an issue where it pours water during the spin cycle, while it is draining. Basically, it pours water from the top while draining it out from the bottom. It drains the water faster than it can pour it, so it does not actually fill with water, but it does re-wet the clothes, so the clothes are dripping wet when the cycle is complete.
It also agitates while filling with water. This is not much of a problem, but it started happening the same time that the other issue above started happening.
Specs
Model: Kenmore Elite 26964503
Desired Outcome
This is what the washing machine is supposed to do:
- Wash Cycle
- Fill with water.
- When full, begin agitating.
- After a while, drain water.
- Rinse Cycle
- Fill with water.
- Spin Cycle
- Spin while draining water.
- When empty, continue spinning and draining.
- After a while, stop.
Actual Outcome
This is what the washing machine actually does (the bold text marks the differences):
- Wash Cycle
- Fill with water while agitating.
- When full, continue agitating.
- Rinse Cycle
- Spin Cycle
- When empty, continue spinning and draining but also begin pouring water from top.
Summary
The main problem is 3-2: in the spin cycle, the machine begins to pour water after it has drained all of the water. It is not supposed to be pouring water at this point; it defeats the purpose of the spin cycle.
What could this be? What would cause it to pour water during the spin cycle?
Esta pergunta é pertinente?
14 comentários
I have the same problem and the tub spins after the wash cycle and the clothes are dry, but the last spin cycle it must spray water cause it spins
por melvin
Same problem. Anyone solved this? As a temp solution I have to close the water during spin cycle. Working till I get another washer
por Anthony Grech
@Anthony Grech
What is the model number of the washer?
por jayeff
@jayeff. Part numbers I see at the back
I can’t match them anywhere.
Part No 3953357. WHT.
There are few more listed all start with 3953
Thanks Anthony
por Anthony Grech
3953358 alm. 3953359 alm
por Anthony Grech
Mostrar mais 9 comentários
