Ir para o conteúdo principal
O HP 15-r137wm TouchSmart contém um processador Intel Core i3 de quarta geração com uma tela touchscreen de alta definição de 15,6" com retroiluminação LED. Ele possui 6 GB de RAM com um disco rígido de 750 GB. O HP 15-r137wm TouchSmart vem completo com o Windows 8. O número do modelo do HP 15-r137wm TouchSmart é 15-r137wm, que pode ser localizado na parte inferior do laptop, no canto direito, abaixo da bateria.
Keyboard Zif separated from MB
I have accidentally separated the keyboard Zif connector on my HP 15-n230sa laptop from the main board. Didn't realise the tab was on the opposite side of the connector and stupidly prised it off the board.
Please would you mind taking a look at the pictures and tell me whether this can be rectified? Is there anyway to reseat it back on the board?
Imagem
Imagem
Thanks in advance!
Esta é uma boa pergunta?
Pontuação 0
1 comentário
I will find some who can re-solder this for me. Thank you very much for answering my question, much appreciated.
por
Adicionar um comentário
2 respostas
Solução escolhida
You are very lucky! The solder pads didn’t get damaged so it should be possible to re-solder the connector back down.
Now the tricky part! To do this right you need a re-work system which uses hot air. Your best bet is to find someone local to you with the needed tools to remount it.
Esta resposta foi útil?
Pontuação 1
go to hit shows on utube, the fellow speaks mostly indian, but if you watch he cuts plastic to fit over the end of the ribbon and a small piece for tension on the underside and heats them and then inserts them and they hold solid.
Pontuação 0
Adicionar a sua resposta
Andrew Hawker será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 15
Ao todo: 447
