Ir para o conteúdo principal
The DZ09 is a Chinese smart watch with basic features and the ability to make calls. These can be as cheap as $10! (Yes, you read that correctly!)
90 Perguntas Visualizar todos
Micro SD Card will not read on watch, works on my computer.
I have a DZ09 Smartwatch I received a few days ago. The only problem is that it won’t seem to read SD Cards. I’m beginning to believe that the slot was dead on arrival, but I’ll ask here for answers. Yes, I have tried multiple SD Cards. They all don’t work.
Esta é uma boa pergunta?
Pontuação 3
1 comentário
Anyway to solve the issue
por
Adicionar um comentário
3 respostas
Solução escolhida
Hi @superdoggo ,
What capacity SD Card are you trying to mount in the watch?
According to this link the maximum supported size is 32GB. Just a thought.
If the cards that you tried were of equal or less capacity than this, then it may be as you said, the SD card slot is faulty.
As it is a new watch, consult the manufacturer’s warranty statement that should be with the documentation that came with the watch, as to what to do to make a claim for a manufacturer’s warranty repair or replacement.
Esta resposta foi útil?
Pontuação 3
1 comentário:
The capacity of the Micro SD Card is 2GB. It is from Sandisk. Also, I don't think I can make a warranty claim due to me ordering it from Wish.
por
Depending on your computer hit win+x then k and make a volume in sd card or ubuntu hit super key type gdisk and format there
Pontuação 0
You need to format the SD card in FAT32 format, exFat and NTFS will not work.
Pontuação 0
Adicionar a sua resposta
SuperDoggo será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 20
Duração total: 4,957
