GPS does not stay on; goes into sleep mode
the GPS does not stay on when turned on now. a box appears stating that the battery needs recharging and it will go into sleep mode. what does this mean and how do i fix it?
Esta é uma boa pergunta?
It means that your battery is either discharged or does no longer hold a charge. If you have an AC or 12V DC adapter, plug you GPS in and let it charge for a few hours. Then unplug it and see if that makes a difference. If not, you will probably have to replace the battery. Instructions for that are on here Good Luck and hope you will soon find your way again...;-)
Esta resposta foi útil?
The GPS for the GPS service may vary but we know about ourselves. We have raised GPS team specifically for the purpose of offering the possible helps to our approaching customers. As far as the process of availing the stated service is concerned, then to have an authentic piece of information, you may get in contact with our expert team. You will be simply required to make a call at our mentioned '''GPS map updates''' tollfree number +61 1800 215 732 Australia to receive answers to your queries in no time.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 1,388
