Powers On but won't show anything
Hello,
I have a laptop HP Pavilion 15 , when I boot it at first it shows a blue screen with a sad face. After that I turn it off and tried to turn it on again but it shows nothing on screen, the light on the power button is on but the screen doesn’t show anything, I tried to connect it with HDMI to a display but it doesn’t show anything even in the display.
Esta é uma boa pergunta?
3 comentários
Ok thank you very much, I'll try it and reply again.
por Savvas Giannoukas
@geekittogether Tried this but again screen does not show anything, just a black screen
Hi,
Can you hear the fan start up (or feel the air from the vent), or the HDD spin up?
Try the 30 second power reset:
Disconnect the charger (if connected), remove the battery, press and hold the laptop's Power button for 30 seconds and release, insert and switch on the charger (leave the battery out at this stage) and try to start the laptop.
If it starts and you have a display, allow it to boot all the way to the windows desktop, allow the HDD activity to settle down and then shut down the laptop in the normal manner.
When it has completely shutdown, switch off and remove the charger, reinsert the battery, reconnect and switch on the charger and try to turn on the laptop.
if it starts with a display, allow it to boot all the way to the windows desktop, allow the HDD activity to settle and then check the charge status of the battery. if it is charging, allow it to fully charge before switching off the charger and disconnecting it from the laptop.
por jayeff
