Ir para o conteúdo principal
15" laptop manufactured by Dell at the end of 2016. The laptop is very configurable, uses 7th generation processors and has a grey plastic chassis.
11 Perguntas Visualizar todos
How can I remove a stripped screw?
I was trying to remove the screw to get into the laptop and ended up stripping the screw. Any idea how I can take it out?? I've tried using superglue, didn’t work
Esta pergunta é pertinente?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta Mais Útil
you can make a small groove at one side like the photo
Esta resposta foi útil?
Pontuação 1
Here’s the iFixit Guide on stripped Screw Removal:
How to Remove a Stripped Screw
Pontuação 1
Their is a special bit/tool that can remove stripped screw heads but cannot recall it’s name!…This problem can occur when the wrong screw driver is used to remove Philips/ Pozidrive type drivers but especially when the tool is not a snug fit and plumb with respect to the screw.
Pontuação 0
Adicionar a sua resposta
Sabeel Hussain será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 10
Duração total: 693
