How can I remove a stripped screw?
I was trying to remove the screw to get into the laptop and ended up stripping the screw. Any idea how I can take it out?? I've tried using superglue, didn’t work
Esta é uma boa pergunta?
you can make a small groove at one side like the photo
Esta resposta foi útil?
Here’s the iFixit Guide on stripped Screw Removal:
Their is a special bit/tool that can remove stripped screw heads but cannot recall it’s name!…This problem can occur when the wrong screw driver is used to remove Philips/ Pozidrive type drivers but especially when the tool is not a snug fit and plumb with respect to the screw.
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 784
