Ir para o conteúdo principal
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
Touchscreen Is Not Responding
I have a 3g Iphone, I notice when i changed the digitizer it will not respond to the touch, wil not slide to open phone, when i took it off and put it on another iphone the screen works perfectly.so i put another working digitizer from another iphone and again the sam problem.is there something wrong on the board as to why this ill not work on this particular phone?
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
1 resposta
Solução escolhida
It sounds like you might be swapping 3G and 3GS front panels. Are you confident both panels are made for an iPhone 3G?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
lloyd será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 542
