Ir para o conteúdo principal
O LG G Vista possui uma tela sensível ao toque capacitiva IPS LCD de 5,7″ junto com uma câmera de 8 MP.
Touchscreen will occasionally not work
My LG G Vista is having a problem where the screen will totally stop responding for varying periods of time. However, after locking & unlocking the phone several times, it will generally start working again. Sometimes I have to restart it by removing the battery.
So far, I have booted the phone in safe mode, and have removed the SIM card. However, neither of those has helped. Any thoughts?
Thanks a bunch!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
That is very common with a defective screen I would change the screen and see if it works if not it could be a board issue and if you find a reputable repair shop that can get the schematics and parts for it they should be able to fix it
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ava Butler será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 11
Ao todo: 217
