Ir para o conteúdo principal
Repair and disassembly guides for GE Microwave ovens.
Power goes off to microwave
Power goes off to microwave. Bang on side with my hand where control panel is can usually get it to come back on. Sometimes will work fine for little while other times power goes right back off GE adora model. Dvm7195sf1ss Any ideas what could be the problem?
Esta é uma boa pergunta?
Pontuação 1
4 comentários
If your circuit is overload the breaker on that circuit will trip too much is on that breaker. You may need to call an electrician to see if your wires can use a higher amp breaker.
por
Thanks for your response
por
It doesn’t cause a circuit breaker to trip
por
I am having the same problen
por
Adicionar um comentário
2 respostas
Solução escolhida
I’ve looked at this question about five times and really didn’t want to answer as I didn’t want the responsibility of you getting knocked on your can from the high amperage stored in this thing. You obviously have a bad electrical connection. Could be a loose wire or cold solder joint. Personally I would not risk trying to repair it.
Esta resposta foi útil?
Pontuação 3
1 comentário:
Thanks fir your response
por
I had the same exact problem. On the pcb it was a weak solder on one of the pins of the low voltage transformer. Took 5 minutes to re-solder it. Also, a dirty micro switch on door. Took another 30 minutes to take apart & clean. Now the microwave works great
Pontuação 0
Adicionar a sua resposta
Glenn kreutzer será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 562
