Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
iPhone 7's 3D touch features and Touch ID not working after repair
My iPhone turned off and would not charge anymore. I checked the Lightning jack and cleaned it out but that didn’t help. I took it to an independent repair guy to have it checked.
The iPhone turned on and is charging but the home button was not responding and 3d touch (force touch) and touch ID weren’t working.
Is this normal?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
You have two (potentially) separate issues here:
  1. You may have damaged the Home Button during the repair. The flex cable part of the HB is very fragile, as is the flex that runs underneath the LCD heat-shield. That would cause issues with the TouchID and click functions, depending on what kind of damage there is.
  2. The 3D Touch feature could just be a poor quality replacement screen.
Start by putting the original screen back to see if the 3D Touch issue is resolved. If it is, then you probably have a cheap or defective replacement screen. As for the HB, do a thorough inspection, preferably under magnification, to see if there is any damage to the HB or it’s flex cable and connector. The HB cannot (usually) be repaired but if the damage if to the screen flex, a new screen would resolve the problem.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Hassan Rao será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 95
