FRP lock blocks flashing!
So it happened that my cellphone was shut down with low battery and i had the OEM locked and now the phone cannot be flashed because it say Custom Binary Blocked by FRP Lock. I tried everything i found on the internet from the smartswitch recovery that ofc didn’t work to flashing the latest firmware that keeps giving me errors like Custom binary (boot,radio,recovery) blocked by frp lock i even tried the frp unlock ect but none of them worked for me. I don’t know what to do anymore. would the erase nand help me smh? Help please it has been 4 days that i cannot solve anything. I cannot enter the recovery mode only download and the phone is stuck on BootLoader nothing happens. sometimes it gives me the red message Custom Binary Blocked by Frp Lock.
Esta é uma boa pergunta?
2 comentários
Dear Tatazi.
Frp lock never effect on Firmware flashing
please use proper tools and firmware then flash it.
after successful flashing. you can unlock frp lock.
if you want know more about this.
please kindly attach some screenshot.
All the best
por jamsheer kp Compartilhar
That's a bit exaggerated or shall I say improperly explained. If OEM is locked you can't use Odin3 to flash the device. It will fail. Go to recovery mode and reset the device to factory which should reset the OEM setting. Some devices have a repair apps in the recovery menu. After resetting the device you then have to clear FRP. (Google account factory reset protection).
por CASPER YOUNG Compartilhar
