Ir para o conteúdo principal
Lançado em 2012, este é um notebook resistente para o uso diário. Este modelo (NP540U3C-A01UB) possui uma tela de 13", um disco rígido de 500 GB, 4 GB de RAM, uma unidade de DVD e é capaz de executar o Windows 8.1.
Help, can't install an OS
So here’s what happened, I tried to install Ubuntu onto my laptop and when I restarted it, well it didn’t detect any OS anymore despite me leaving the USB inside. (It was originally a windows 10)
Now whatever I do, it doesn’t detect any USB input, let it be a USB keyboard, mouse or drive. The only thing I have access to is my BIOS.
It doesn’t seem like my laptop still has an OS and it refuses to do anything else.
Letting it boot normally gives me:
“All boot options are tried. Press F4 key to recover with factory image using Recovery…“
After pressing F4, well it doesn’t detect anything and goes on it’s merry way back to the afore mentioned quote.
Thanks is advance!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi @kansysaea ,
In BIOS change the Fast BIOS mode setting to disabled
When Fast Bios mode is enabled it skips USB check during POST.
Go to BIOS > Advanced > Fast BIOS mode
When exiting BIOS (F10) save the changes (Y).
When the laptop restarts you should be able to boot from a USB device.
Esta resposta foi útil?
Pontuação 3
2 comentários:
thank you very much @jayeff for your wonderful advice. It works
por
Thanks jayeff ! , works too in UEFI mode
por
Adicionar a sua resposta
Andrew Kansy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 12
Últimos 30 dias: 26
Ao todo: 2,045
