Wrong current/voltage plugged into charging port
Daughter plugged rigged electric razor charger into charging port of phone device totally unresponsive how to fix
Esta é uma boa pergunta?
you will have to disassemble your phone. you can use these guides ZTE ZMAX or something like this video Then check your motherboard for any damaged component (PMIC,capacitors or resistors). Usually with an overvoltage you will have obviously damaged components. Here comes the real problem, schematics are not readily available. So, there will be a lot of guessing etc. to determine what needs to be replaced. It is possible that this is a damaged battery (replacing it will rule it out/in).
You can of course post some good pictures of your motherboard etc. with your question so we can see what you see. somebody may see and recognize any damaged components. Adicionar imagens a uma pergunta já existente
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Duração total: 37
