Ir para o conteúdo principal
LG 65LB730 Screen problems, pulsating
Hi, my TV have randomly started pulsating some lines on the objects.
I’ve tried to reset the tv to factory settings and also upgraded/downgraded the fw and problem still issue.
Clip on the issue.
https://www.youtube.com/watch?v=2gs6PVba...
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Jakob Vesterberg
this could be an issue with the main board. Try different video input sources (HDMI, Composite, Coax etc.) and see if it remains. If so, I would consider replacing the main board.
Esta resposta foi útil?
Pontuação 2
You are experiencing a TV with an LED problem. Very common. I have repaired these under warranty. Your TV panel is the culprit. You may try to replace the LEDs. This is extremely difficult and can result in a complete waste of time. Recycle and shop for new. Thanks for asking, Matt of Martins TV Repair.
Pontuação 1
1 comentário:
Then I know, thanks for the help :)
por
Adicionar a sua resposta
Jakob Vesterberg será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 312
